LDAP: Adding Users to Group
justin_drysdale
Mega Guru
I am running into an issue with group imports and adding users to groups.   I am using ldapUtil.addMembers(source,target) in an on-after transform script which works for the most part.   Users are being added to groups.   However it looks like it is also adding users to non-existent phantom groups.
In 'sys_user_grmember' after the import, I see ~300 records where there is a valid user and an invalid group.   I've queried some of the phantom groups and they report back with:
"Get for non-existent record: sys_user_group:d6c2c871ad2e6100998001b56318c5f8, initializing".
Odd how the non-existent group has a sys_id.   If I take the sys_id and query 'sys_user_group' the group doesn't exist.   Any idea what could cause this behavior?
I also checked deleted records and did not find any matching sys_ids.
Are you sure these groups have been created with the import?
I had this behavior when I cloned an instance and added the sys_user an sys_user_group to the exclusion list, causing all the references to be maintained, but links still pointing to the old sys_ids of users. This messed up all the tables used to link a user to a group, a role or basically anything...
I think in your case it messes up, because it probably tries to link to a group that is not yet existing or your script that returns the group to link to, returns a faulty value. Try to add an if-statement, verifying the group you try to link your user to.
I'm not really into using 'ldapUtil.addMembers(source,target)' as I got no or wrong results. Unfortunately there is no real documentation on how to use it, and retracing the source-code of it made me think to use an easier method.
I found a really simple script written by Mark Stanger (Crossfuze) and explained in this discussion:
Can you add users to Groups with script?
I slightly modified the script to be used also in an onAfter transform script (on a transform map that is importing Users from our Active Directory), it works like a charm:
//Create a new group relationship record for this user
var addUsr = target.sys_id;
var toGrp = 'Your_Group_SysID_here';
var rec1 = new GlideRecord('sys_user_grmember');
rec1.addQuery('user',addUsr);
rec1.addQuery('group',toGrp);
rec1.query();
if(!rec1.next() && !addUsr.nil() && !toGrp.nil()){
  rec1.initialize();
  rec1.user = addUsr;
  rec1.group = toGrp;
  rec1.insert();
Kind Regards,
Michel Conter
14 REPLIES 14
I don't have this problem. Seems for me more like you did not set a proper coalesce value on the import, causing your problem.
I use for user and group import the GUID as coalesce value, like this you can even change the name, username, etc... without any repercussions
I was thinking of making my own add to group function, but I see that this wheel has already been invented.   Thanks for the link!
No problem Just a little side note: when implementing the script, make sure to check if the membership already exists. Otherwise you end up with a lot of double entries. I just updated the script part of my comment a bit.
Hi Michel,
What attribute from LDAP will bring me the user group membership info?
I am trying to import groups and members from LDAP. User import and Groups is working but members are not being added.
Any help is much appreciated.
member adds group memberships.
Our LDAP attributes list looks like this;
dn,EmployeeNumber,employeeID,givenname,mail,sn,source,telephonenumber,title,physicalDeliveryOfficeName,sAMAccountName,department,manager,description,managedby,displayname,othertelephone,company,distinguishedName,member,objectGUID
