Location is Not populating
pramn
Team ,
We have  a Catalog in catalog we have a variable called Physical Office Location,
That variable refers to cmn_location table , and when we have created couple of locations That location is not showing under the Variable (Physical Office Location), can some one help me if any thing wrong I am doing ?
need your assistance
9 REPLIES 9
Sandeep Rajput
@pramn Please check if there is a reference qualifier defined on your location variable on catalog item. This reference qualifier might be preventing your location from being shown in the field.
Yes you  are right.
i am unable to understand can you help me with it
@pramn The reference qualifier is not quite visible in the screenshot. However, it is filtering the records. If you do not want to have this filter in place then simply remove everything from this field and the location field will show all the records.
sys_tags.bbf884771b104158ac17c992604bcb1a=bbf884771b104158ac17c992604bcb1a^ORsys_tags.027f8c3b1b504158ac17c992604bcb67=027f8c3b1b504158ac17c992604bcb67^ORsys_tags.4af5b3591b47fcd0dd0743b3cd4bcbde=4af5b3591b47fcd0dd0743b3cd4bcbde^ORsys_tags.40ed4fdd1bed49d0dd0743b3cd4bcb9a=40ed4fdd1bed49d0dd0743b3cd4bcb9a
@pramn Since this reference qualifier is full of sys_ids, I am not sure what exactly it is doing. I recommend removing it if you wish to show all the locations.
