Lookup Select Box not mapping on a Record Producer
rconstantino
We currently have a reference variable on a record producer that we would like to change to a lookup select box .
As a reference variable, the mapping is successful.
When I change the variable type from reference to lookup select box, the variable no longer maps.
Is there a way to map this?
Thank you,
Rachel
2 ACCEPTED SOLUTIONS
Chaitanya ILCR
Giga Patron
Hi
update the lookup field to sysid
and lookup label to full_name
also make sure name of the variable is same as the field bakend name
Chaitanya
Shruti
Update look up value field to SYSID and look up label field to full name (Make sure to check backend name of Full name field)
9 REPLIES 9
Chaitanya ILCR
Giga Patron
Hi
Chaitanya
Hi @rconstantino ,
I did share the same thing 🙂. could you please accept my response as helpful and accept it as a solution too?
you can accept multiple solutions
Chaitanya
Shruti
Thank you!
Ankur Bawiskar
@rconstantino
Please follow the step mentioned by @Chaitanya ILCR and it should get mapped.
