Making catalog task variable readOnly
Asmita7
Hello friends,
There are 3 editable variables on catalog task form.
1. checkbox
2. Emp ID
3.  Temp ID
If the check box is selected then the Emp ID should be read only.
I cannot fetch the checkBox variable in UI policy condition.
Even the checkBox variable is not available in onChange Client Script's Field Name list ??
How to set this condition in UI policy or onCHange client script's Field name?  Please suggest.
12 REPLIES 12
All these variables were created on catalog and available on catalog task. I will share the screenshot if required.
Yes, please share the screenshot.
saicharan3
Hi @Asmita7
Can you please upload the screenshot of checkbox, so that it would be easier to resolve the issue.
ersureshbe
Hi, why you should set as read only instead of disable the visibility using UI policies
Suresh.
But the variables are not accessible in UI policy to set condition. Is shows only one field Variables and not the separate variables.
