Making Multi row variable set visible when a particular variable is selected
09-04-2019 04:31 AM
Hi All ,
I have used a Multi row variable set in a service catalog .Now the variables of that Variable set should be visible when request type is Firewall .
then the Multi variable set should be visible :
However in catalog UI policy there is no option to see the Multi variable set variable.
Can anyone help me to achieve the requirement ,.
Service Catalog
09-05-2019 02:20 AM
Ah you are not about the MRVS itself, though the variables of the MRVS. Is that correct?
If so, you can't control the visibility within MRVS from outside the MRVS. Maybe with New York it can, haven't checked that yet. But London/Madrid, unfortunately: no go.
Kind regards,
Mark
09-11-2019 09:06 AM
Hi there,
Did this solve your question? Or do we need to follow-up on this?
Please mark this answer as correct if it solves your question. This will help others who are looking for a similar solution. Also marking this answer as correct takes the post of the unsolved list.
Thanks.
Kind regards,
Mark
