Map Catalog item variables to request fields using run script in custom workflow
Imatiaz
I have created three variable Requested for, location, description.
now  I need to map these variables to request fields using Run script. or any other recommended way for mapping.
@Ankur Bawiskar @Pradeep Sharma
Ankur Bawiskar
Please use this script in your workflow of catalog item
var req = new GlideRecord('sc_request');
req.get(current.request);
req.requested_for = current.variables.requested_for;
req.location = current.variables.location;
req.description = current.variables.description;
req.update();
It is recommended to have only 1 workflow on sc_request table
This is OOB Service Catalog Request.
If you disable it this will impact your entire platform.
Ideally you should have workflows on your catalog item and not Request table
It is not working not mapping any value on request form.
Is your workflow on catalog item i.e. sc_req_item then the above should work provided you are using valid variable names and valid field names on REQ
Hi Ankur,
Above code is not setting the location.
