Mapping of field in Asset & CI
_bhishek
I want to map one field named as 'end of life'.How can i map this field in Asset & CI .This field is available in alm_hardware table and cmdb_ci_hardware table.
Please suggest.
Thanks .
14 REPLIES 14
Hi Gundeep,
Thanks for this! I got it to work the one thing with your instructions is it says to remove all attributes from asset field but I needed to keep fieldChoicesScript=GetFilteredTableFields in the attribute field for it to work.
Ben
Ashutosh Munot1
HI,
Let me start from this question:
When do you want this to get mapped? i.e. Creation or Updation
Ashutosh
_bhishek
Thank you all for your responses .I have completed the requirement.
Are you able to share your solution here? I am experiencing the same sort of issue here where I need to map child tables.
Benjamin Charle
I Was able to get this to work just like @Gundeep Singh said. The only exception was I needed to keep fieldChoicesScript=GetFilteredTableFields in the attribute for asset field and CI field
