Match not found, reset to original
08-01-2020 04:35 AM
I'm trying to autopopulate business service when assignment group change. whenever I'm trying to change the assignment group and saving that task "Match not found, reset to original" this error showing.
Business service table name is "cmdb_ci_service". I have checked the value is exist on table.
I have tried add sys_id or valve no difference same error showing.
Below is my code
Please suggest
Sowmya
08-01-2020 07:58 AM
Thank you for replaying my query, Issue is already resolved. Another script running based on assignment group.
Sowmya
08-01-2020 09:47 AM
Hi Sowmya,
Good to know you got it working as comments as above helped where some other script or dependancy field was to be checked. Kindly close the thread by marking appropriate answer correct so that it does not appear in unanswered list.
08-01-2020 09:50 AM
Hi
Please mark one of the responses as correct so that this thread is marked as resolved.
All the best. Have a good one!
Berny
08-01-2020 06:25 PM
If you got it working by yourself, please mark your own answer as a solution so this thread will be resolved.
