Multiple reference field entries
tgcorbin
Mega Contributor
I have a reference field on a service catalog item. It is a reference table that is tied to the users. Is there a way to make it so that I can have multiple entries in that field, or can only one be allowed? I want to use this field for a CC: field on an email, so being able to have multiple users would be nice.
Jon G1
Hello from many years in the future.  Since this came up in a google search of mine, I just wanted to leave the answer I found for the next person:
Set the variable type to "List Collector" and add the variable attribute "glide_list"
Variable attributes
Prathamesh G
Hello @tgcorbin,
Please use the field type as 'List Collector' and refer to the 'User' table. So by using the type as 'List Collector', you can able to select multiple reference field values in your field.
If the above solution resolve your issue, Please mark the solution as 'Accepted Solution' and also mark it as 'Helpful'.
Thank You!
Prathamesh.
Prathamesh G
Hello @tgcorbin ,
Please refer to the below screenshot to create the List Collector variable on your Catalog item.
Thank You!
Prathamesh.
