Multirow Variable set not visible in Record Producer when I click on Try it button
HI Team,
I have created a Record Producer with some variables with containers in it. I also created a MRVS without any containers as in the below screenshot
But when I open the record producer and click on "try it" I see all the variables which are in record producer but I do not see the MRVS at all?
Please help
@Dr Atul - LNG Thanks for the suggestion but the issue is fixed now , It was because I did not end the container in the variables in record producer 🙂
No @Community Alums
@Community Alums  got the answer even before I replied, but yes, to confirm, he can accept our answer too.
Hi @Community Alums ,
on the record producer, you will have variable set option in related list section. you can edit and add new set from there (if it is not available, configure related lists to bring it on the form).
Also, be causious of below:
make sure all the variables are active in variable set.
make sure you don't have duplicate variable sets with the exact same name
please put the orders in variable and variable set to arrange it on the form.
please check for any UI policy affecting its visibility.
