Mutliple users select in requested for field choices
Manohararuna
Hello Everyone,
       I have one requirement.
Requirement is In Catalog form having the Requestor For field (reference type--user table) and Application filed(reference type- App table) .If i select Minipay in Application then i am able to select multiple users in Requestor For field. This requirement only for Minipay option .suppose if i select another application then i am able to select single user at time in Requestor For field.
Please provide solution to this one.
Manohararuna
2 ACCEPTED SOLUTIONS
Rafael Batistot
Mega Patron
Hi @Manohararuna
The Requested For variable in a catalog item is a reference type (to sys_user). Out-of-the-box, reference variables only allow one value. To allow multiple selections, you need to use a Lookup Select Box / Multi-row variable set / Glide List.
So the trick is:
  • You actually need two different variables:
    • requested_for_single → type = Reference (sys_user), for normal use.
    • requested_for_multi → type = Lookup Select Box (or Glide List), for Minipay.
  • Then use a Catalog Client Script (onChange of Application) to show/hide the right one.
Example Client Script
  • Type: Catalog Client Script
  • Applies to: Item
  • When: onChange → Application
    // If Application = Minipay
    if (g_form.getDisplayBox('application').value == 'Minipay') {
        g_form.setDisplay('requested_for_multi', true);
        g_form.setMandatory('requested_for_multi', true);
        g_form.setDisplay('requested_for_single', false);
        g_form.setMandatory('requested_for_single', false);
        g_form.clearValue('requested_for_single');
        g_form.setDisplay('requested_for_single', true);
        g_form.setMandatory('requested_for_single', true);
        g_form.setDisplay('requested_for_multi', false);
        g_form.setMandatory('requested_for_multi', false);
        g_form.clearValue('requested_for_multi');
If this response was helpful, please mark it as Helpful and, if applicable, as Correct.
This helps other users find accurate and useful information more easily
Shashank_Jain
@Manohararuna ,
  • Create Reference variable for single selection.
  • Create List Collector for multiple selection.
  • Control visibility via Client Script.
  • Only one will be shown at a time depending on Application selection.
If this works, please mark it as helpful/accepted — it keeps me motivated and helps others find solutions.
Shashank Jain
Shashank_Jain
@Manohararuna ,
Shashank Jain
