Need help variable section on Catalog task
sunil maddheshi
Hello everyone,
I am working on a requirement to create a set of automated tasks on a daily basis and assign them to a specific group. For this, we have a catalog item, and I have created a daily scheduled job that generates the RITM along with the associated catalog task for each product.
The scheduled job script is working as expected; however, the Variables section is not visible on the catalog task when it is created through the script. My requirement is to display the catalog item variables on the sc_task so that the assignee can fill them in before closing the task.
Below are the scheduled job script and the task screenshot for reference. Please help or suggest any alternative solution for this
// Submit Automated Task
var catalogItemSysId = 'e6067ec0c346725062c17ebdc0013130';
var sourceTable = 'u_automated_products';
var query = 'u_frequency=Daily^u_time_to_run=8 AM ET';
var gr = new GlideRecord(sourceTable);
gr.addEncodedQuery(query);
while (gr.next()) {
    var cartId = gs.generateGUID();
    var cart = new Cart(cartId, gs.getUserID());
    var item = cart.addItem(catalogItemSysId);
    cart.setVariable(
        item,
        'short_description',
        gr.u_product_name+" " + gs.nowDateTime()
    var cartResult = cart.placeOrder();
    if (cartResult && cartResult.sys_id) {
        var requestSysId = cartResult.sys_id;
        gs.info('Request created: ' + requestSysId);
        var ritmGR = new GlideRecord('sc_req_item');
        ritmGR.addQuery('request', requestSysId);
        ritmGR.query();
        if (ritmGR.next()) {
            gs.info('RITM found: ' + ritmGR.sys_id);
            var scTask = new GlideRecord('sc_task');
            scTask.initialize();
            scTask.request_item = ritmGR.sys_id;
            scTask.short_description = gr.u_product_name +" "+  gs.nowDateTime();
            scTask.description = 'Automated task created for '+gr.u_product_name;
            scTask.assignment_group = 'e8cf3e18c34ab25062c17ebdc0013155';
            scTask.state = 1;
            var taskSysId = scTask.insert();
            gs.info('SC Task created: ' + taskSysId);
Chaitanya ILCR
Giga Patron
Hi @sunil maddheshi ,
try setting variable's Global field value to true of your catalog item to
Chaitanya
Shashank_Jain
Variables are visible on catalog task if we submit the catalog item through the portal?
@Shashank_Jain  yes, when submitted though portal variables are visible.
Chaitanya ILCR
Giga Patron
Chaitanya
@Chaitanya ILCR Thank you so much, it worked like magic.
