ā12-05-2019 01:18 AM
I am trying to set a Lookup select box to work with a dependant field.
The dependant field is called current.variables.request_source. (Possible values: internal/external)
This does a direct lookup from the Choices list of the backend table
The reference qualifier I am using is:
javascript: "name=u_XXX_access^inactive=false^element=u_work_type^dependent_value=" + current.variables.request_source + "^EQ"
This works correctly and exactly as expected in the Service Portal but in the Platform UI Service Catalog the menu is always empty
As a test I tried replacing the variable with a fixed string like this:
javascript: "name=u_XXX_access^inactive=false^element=u_work_type^dependent_value=" + 'internal' + "^EQ"
Then it work in both Service Portal and Platform UI Service Catalog (but obviously is not dependant)
Anyone have any suggestions why this qualifier is not working in the Platform UI Service Catalog?
Service Catalog
ā12-10-2019 03:37 AM
OK, so I figured out the answer myself and here are the details for anyone else who has this problem
While this technique works well of the Catalog Item when viewed from the Service Portal it needs to have additional configuration to make it work properly when accessing the Catalog Item from the Platform UI Service Catalog
On the Default Value tab(!) there is a Variable Attributes field and this needs:
ref_qual_elements=<variable used to filter>
In this instance:
ref_qual_elements=request_source
Which matches the "current.variables.request_source" specified in the 'Reference qual'
With this in place the filters work in the Request Item in both the Service Portal and Platform UI Service Catalog
ā03-06-2025 05:46 AM
Jesus Christ i frickin'g love you. I was sitting on this for 3 days trying to figure.
ā03-06-2025 07:16 AM
Thanks for the love š
ā04-13-2026 12:19 PM
This really helped me with the same problem. Thank you for sharing!
ā04-14-2026 12:51 AM
Glad to have helped š
