Need to cancel submit a form using glide ajax
amit164
Giga Contributor
when a user enter a short description which is already exists,then form submission should aborted.
i am using on submit client script and glide ajax.
all i want to cancel sumission on the basis of result from script include.
how is it possible plz suggest
If you used same then you should mark my response as correct.
But anyway what important here is solution to your query and you got that.
Dhananjay.
14 REPLIES 14
very much similar to yours.
infact same i can say
Dhananjay.
Dhananjay Pawar
Hi Amit,
Any update on this?
Do we need follow-up on this? If this has resolved can you mark this as correct and helpful so others will refer same in future and also this will remove from unanswered thread.
Dhananjay.
Prasant Kumar 1
Please follow the below screenshots:-
If i was able to solve your query, please mark my answer correct and helpful.
Thanks & Regards
Prasant kumar sahu
thank u for support
