Need to change "requested for" for catalog items
Abhishek Rai
Hello Everyone,
I have a problem with service catalog whenever any one requested on behalf of any other user. Then after raising the request it will set requested for as the the requestor not "on behalf of user"
Variable set is also fine see the below picture see the attachment,
The question what need to be set so that when i select another user and raise the request then it need to set the requested for as the user for whom i raised the request "on behalf of user" not my name.
Please suggest if any one have solution of that issue.
Thanks in Advance
Abhishek Rai
I'm having the same issue. Yes, REQ for shows as logged in user. Will try your solution. Thank you.
