Need to edit on Knowlage base affected product by using ITIL access
rajibosss11
When i Try to add Affected products in Knowledge articles its working only for knowledge admins its not working for ITIL in M2M table
please suggest solution for this
vaishali231
hey @rajibosss11
This behavior is typically related to ACL permissions on the M2M table used for Affected Products, rather than the Knowledge article itself.
By default, knowledge_admin works because it has elevated access, while itil users often don’t have create/write access on the M2M table.
What to check
  1. ACLs on the M2M table
  • Navigate to System Security - Access Control (ACL)
  • Search for the M2M table (e.g. m2m_kb_knowledge_product)
  • Review these operations:
    • create
    • write
    • read
Make sure the itil role is allowed either:
In the Requires role field, or
In the ACL script (if present)
scripted ACL :
answer = gs.hasRole('itil') || gs.hasRole('knowledge_admin');
  1. Validate using Debug Security Rules
  • Go to System Security - Debugging - Debug Security Rules
  • Impersonate an ITIL user
  • Try adding an Affected Product
This will show exactly which ACL is blocking access.
Additional checks
  • Related list configuration - ensure the ā€œNewā€ button is not restricted
  • Confirm the user has write access to the Knowledge article
  • Check for any UI Policy/Data Policy making it read-only
If this response helps, please mark it as Accept as Solution and Helpful.
Doing so helps others in the community and encourages me to keep contributing.
Vaishali Singh
Tanushree Maiti
Hi @rajibosss11 ,
Out of the box, the M2M table is an internal backend table with access restricted to administrators.
Before granting an ITIL user create/write access to the M2M table, carefully consider the potential implications.
If still you are looking for enhancement, you can use ACL .
Note: In Following post -  you can see a post where other member created a custom M2m table and using Read ACL they have given  ITIL Role.
https://www.servicenow.com/community/developer-forum/custom-m2m-table-records-not-visible-to-itil-no...
vaishali231
hey @rajibosss11
What to check
    • create
    • write
    • read
scripted ACL :
Additional checks
Vaishali Singh
hey @rajibosss11
Hope you are doing well.
Did my previous reply answer your question?
If it was helpful, please mark it as correct āœ“ and close the thread . This will help other readers find the solution more easily.
Vaishali Singh
