need to fetch task number from the email body
srinidhi
Hello All,
I need to fetch sctask number from the email body and I need to update the record.
please help me with the script.
example number: SCTASK1234567.
Thanks.
Musab Rasheed
Below is example of fetching number from Subject, you can replicate for body as well.
https://www.servicenow.com/community/service-management-forum/need-to-extract-incident-number-or-cha...
Musab
13 REPLIES 13
@Musab Rasheed@Ankur Bawiskar
The above link helped me in fetching the task number.
but am unable to update the reference field from the script.
(function runAction(/*GlideRecord*/ current, /*GlideRecord*/ event, /*EmailWrapper*/ email, /*ScopedEmailLogger*/ logger, /*EmailClassifier*/ classifier) {
	var subject = email.subject.toString();
        var regex = new SNC.Regex('/SCTASK\\d{7}/im');
        var match = regex.match(subject);
        var task = new GlideRecord('sc_task');
    task.addQuery('number',match);
    task.query();
    while(task.next())
        task.work_notes = 'email.body';
		task.u_digilocker.u_locker_status = 2;
        task.update();
})(current, event, email, logger, classifier);
Which is reference field here ? generally you should pass sys id as reference field value but I don't see it here
Musab
can you provide me the sample syntax please.
like
task.assigned_to = "sys id of user";
Like this
Musab
Hello @Ankur Bawiskar  @Musab Rasheed
As per the above requirement i written below script. First part is working fine (gliding to task table and updating the worknotes)
But second part is not working (unable to update the stockroom table).
can you please and help me.
    task.query();
    while(task.next())
		var status = task.getValue('u_digilocker');
		gs.info('namee: '+ status);
        task.work_notes = email.body_text();
		task.state = 2;
        task.update();
		var st = new GlideRecord('alm_stockroom');
		st.addQuery('name',status);
	gs.info('abcd' + status);
		st.query();
	while(st.next()){
		st.u_locker_status = 2;
		st.update();
