01-23-2022 10:44 PM
Hi Team ,
I have created 2 separate business rule after record get inserted or updated in to my custom table i need some validation and when that record get deleted i need some validation,
I have created 2 separate Business rule
First BR- When After -insert or update
Second BR- When After -delete
This 2 BR's are working fine as per my requirement, but i am thinking to collage 2 BR in to Single BR and below is the code , but its seems not working anyone can help to correct me here ,
Combined BR- 1st+2nd
When- After -insert, update ,delete
table- u_custom
Script-
if((current.insert==1)||(current.update==1))
gs.addinfoMessage('Insert or update operation is happened..');
else if(current.deleteRecord()==1)
gs.addinfoMessage('Delete operation is happened..');
Can anyone let me know is this correct approach which is am doing ??
I need the validation like when record is inserted in to the table field "u_xyz" check box should get True and when that record get deleted from the table checkbox should get false.
Thanks in advance!!!!!!
01-23-2022 11:04 PM
You can combine your both BR into a Single one. Create a After BR on your Custom table and make sure to check Insert, Update and Delete checkbox as True.
Now in your script you can handle like below:
if(current.operation() == 'insert'){
gs.addInfoMessage('Text here');
}else if(current.operation() == 'update'){
}else if(current.operation() == 'delete'){
Say for example, I have used a similar thing to update Reassignment count on Parent Incident record when child Incident task gets insert and deleted accordingly. Sharing a sample script for reference:
// Add your code here
updateReassignCOunt(current);
decreasecount(current);
function updateReassignCOunt(current){
var count = 0;
gr.addQuery('sys_id',current.incident);
if(gr.next()){
count++;
gr.reassignment_count = parseInt(gr.reassignment_count) + count;
gr.update();
function decreasecount(current){
var count = 0;
if(gr.next()){
count++;
gr.reassignment_count = parseInt(gr.reassignment_count) - count;
gr.update();
})(current, previous);
Shloke
01-23-2022 11:48 PM
Did you try on what I have mentioned?
Shloke
01-23-2022 11:52 PM
Oo Yaa,
Its working perfectly ....
Thanks Shloke !!!!!
01-23-2022 11:57 PM
Glad it worked for you. Recently I gave a answer on a similar requirement of your so knew it will work out.
Shloke
