Need to visible only managers in reference field on incident table.
Mallika1
Giga Contributor
Hello Developers!
I am trying to get only managers in reference field on incident table.
I have tried with manager is not empty condition in reference qualifier, it shows users those have managers.
But I need to get only managers in field.
Please anyone suggest me.
Thanks in advance!
update as this to show only the managers
var GetUsers = Class.create();
GetUsers.prototype = {
	initialize: function() {
	getOnlyManagers: function(){
		var arr = [];
		var gr = new GlideRecord("sys_user");
		gr.addQuery("manager", "!=", "");
		while(gr.next()) {
			arr.push(gr.getValue('sys_id'));
		var arrayUtil = new ArrayUtil();
		arr = arrayUtil.unique(arr);
		return arr.toString();
	type: 'GetUsers'
11 REPLIES 11
So what is required?
The script will return only those users which are managers. Is that not required?
Are you saying when user does the lookup you need to show additional field (manager) along with Name, First Name, Last Name, Email?
Need to get only managers.
then the advanced ref qualifier I gave should give you only those users who are manager of somebody
It shows only managers but it show duplcates also, that means it show double times if the manager has two users.
		var arr = [];
		while(gr.next()) {
	type: 'GetUsers'
