Not running the flow designer trigger type is scheduled
srikriti
My client wants
From third party tool we have fetched users data by an action i want to import into the custom table "u_users" we have
through flow designer scheduled type but it is not running flow why?
is there is any other way we can do?can anyone help me on this
i have done with scheduled job also by calling that flow into the scheduled job still not running how should i do this
Please guide me on this.
Hi @srikriti ,
when i click on Execute now button will work that it only manually working fine
so this will work
the schedule job runs at mid night (00:01:00) system time zone
is this means every one minute ?
no it doesn't run every one minute
it run at midnight 12:01 mins
if you want it to run at every one minute
trigger should be of type periodic(repeat)
this will work you just need to adjust trigger as per your requirement
Chaitanya
9 REPLIES 9
Ankur Bawiskar
@srikriti
none of your scheduled flow are triggering?
check this link
Scheduled Flow Not Running at expected daily trigger time
Chaitanya ILCR
Giga Patron
Hi @srikriti ,
you don't have to create a scheduled job separately the system will create one
name of the scheduled job  would = Trigger.{sysid of the schduled flow}
Chaitanya
Hi @Chaitanya ILCR
I could not find mine in this table
@srikriti
did you get a chance to check the link I shared above?
