Notification for an Expiring Knowledge Article
cnharris1
Is there a way to send out a simple notification to the authors of a knowledge article to let them know that their article is about to expire? If so, how would I go about doing that?
Archana Reddy2
A Scheduled Job can do your work. Try with the below one.
var ka = new GlideRecord('kb_knowledge');
ka.query();
while(ka.next())
var exp = new GlideDateTime(ka.exp_date).getDate(); //Considered exp_date as Article Expiry Date
if(exp.addDaysUTC(7)==new GlideDateTime().getDate())
gs.eventQueue('your_event_name',ka,gs.getUser()); //Include the recepients you require
//Running this Scheduled Job daily will send notification 7 days before the ExpiryDate
//You have to create a notification to be triggered when 'your_event_name' is triggered
Hope this helps!
Archana
Glad to hear that 🙂
