09-01-2023 05:21 AM
There is 1 category under which there are 9 catalog items. There is one specific user who wants to get notified whenever any one item is ordered from that category.
How to achieve this?
Thanks in advance!!
09-01-2023 06:47 AM
Hello @Vaishali 11
follow the below steps:
1. Create one event in Event Registry
2. Create After business Rule on Requested item table on insert and write below script.
if(current.cat_item.category=='b06546f23731300054b6a3549dbe5dd8'){ //replace sys_id with your catagory sys_id
gs.info('catagory'+current.cat_item.category);
gs.eventQueue('your_event_name',current,current.number,gs.getUserName()); //
3. create notification on Requested item table and add that User in who will receive tab
Mark my answer correct and give 👍if this helps you...
09-01-2023 06:47 AM
Hello @Vaishali 11
09-06-2023 12:19 AM
Hi Rohit,
I followed the exact same steps as mentioned above, but the notification is not triggered. The email is not generating. Could you please suggest?
09-12-2023 02:55 AM
Could you send the screenshot of notification and business rule?
09-12-2023 06:13 AM
It's working now.Thanks!!
