on change and onload Client script is not working
tushar_ghadage
Hi all ,
I have requirement where
when i open a new change task record default state is pending (-5)
so when its in pending state i want to hide close state (3).
and after i save the form then when i change the state to any other choice like open , cancelled or in progress
then close should appear back again ( both choices are in state field )
for this I wrote on load and on change client script:
function onLoad() {
// Delay to ensure choices are fully rendered
setTimeout(function () {
// Always add "Closed" in case it's missing
if (!gForm.getOption('state', '3')) {
gForm.addOption('state', '3', 'Closed');
// If state is 'Pending' (-3), remove "Closed"
if (gForm.getValue('state') == '-5') {
gForm.removeOption('state', '3');
}, 300); // Wait 300ms for form to finish rendering
if (isLoading) return;
// Always re-add "Closed" in case it was removed earlier
// If user selects "Pending", hide "Closed"
if (newValue == '-3') {
but both of them are not working
could any one suggest whats wrong here
thanks!!
@tushar_ghadage
Hope you are doing good.
@tushar_ghadage
