on change client script is not working for particular catalog item
12-24-2024 01:13 AM
I have written below client script but it is not working for my catalog item it is apply for all catalog item.
kindly let me know what is issue.
var catitem = g_form.getValue("u_catalog_item");
alert(catitem);
//g_form.addInfoMessage("line 9 testing");
if(catitem == '9c9df05597661e500cb57bae2153afe2')
alert("askhr");
if(g_form.getValue('state') =="7")
g_form.setValue("close_notes", "123455");
g_form.setValue("u_knowledge_article", "no");
g_form.setValue("u_support_type", "desk");
g_form.setValue("u_resolution_code", "Solved (Permanently)");
g_form.setValue("u_via_kb_article", "no");
Thanks & Regards
KP
12-24-2024 02:36 AM
you want this script to run only for 1 catalog item right?
then have you given the correct catalog item sysId in the comparison?
also are you sure the section is visible on the form for that catalog item?
12-24-2024 02:40 AM
Hi Ankur,
I have given correct sys_id.
Thanks & Regards
KP
12-24-2024 02:58 AM
is it getting inside the IF?
any other script is setting the fields with other value?
out of 5 fields which fields are not getting set?
01-01-2025 06:13 AM
Hope you are doing good.
12-24-2024 01:24 AM
Hi @keval3 ,
Your code is not proper, use below code.
// Exit the script if it is loading or if the new value is empty
// Check if the catalog item matches the specific item
if (g_form.getValue("sys_id") === '9c9df05597661e500cb57bae2153afe2') {
alert("This is the correct catalog item!");
// Perform further checks for specific field values
if (g_form.getValue('state') === "7") {
