on submit client script is not working
onsubmit client script is not working
function onSubmit() {
  var gr = g_form.getValue('action');
  if (gr === 'sharing') {
    alert('Chandan Patra');
    return false; // Prevents form submission
  return true; // Allows form submission
 Thanks and Regards,
Chandan
svirkar420
Hi @Community Alums , Try the below code I am sharing this should work fine,
return false;
But if this is not working then there might be some conflicting conditions in your instance, which is bypassing the script that you are writing.
If this answer helps you in any ways please mark this as an accepted solution or helpful so it will benefit other readers as well.
Saurabh V.
