on submit client script
tushar_ghadage
if some tries to resolve (using an Ui action) the problem record and if there are open problem task records, I want to restrict that and keep the state in fix in progress state only.
I am trying this using on submit client script and not business rule because when I try to resolve it state will temporarily move to resolve state but when I refresh it, it will move back to fix in progress. and I don't want that. nor did the client.
so here is the script below -
client script - on submit
function onSubmit() {
    // Check if state is changing to "Resolved"
    var state = g_form.getValue('state');
    if (state == '106') {
        var problemSysId = g_form.getUniqueValue();
        var ga = new GlideAjax('CheckOpenProblemTasks');
        ga.addParam('sysparm_name', 'hasOpenTasks');
        ga.addParam('sysparm_problem_sys_id', problemSysId);
        ga.getXMLAnswer(function(response) {
            if (response === 'true') {
                g_form.addErrorMessage('There are active Problem Tasks. These need to be closed before resolving the Problem');
                return false;
                return true;
        //return false; // Stop default submit until GlideAjax completes
    return true; // Allow submit if not resolving
script include -
var CheckOpenProblemTasks = Class.create();
CheckOpenProblemTasks.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    hasOpenTasks: function() {
        var problemSysId = this.getParameter('sysparm_problem_sys_id');
        var gr = new GlideRecord('problem_task');
        gr.addQuery('problem',current.getUniqueValue());
        gr.addActiveQuery(true);
        if (gr.hasNext()) {
            return 'true';
        return 'false';
but here something seems to be missing as when I try to resolve the problem even when there are active p Task it will get resolved and state will move ahead.
please do correct ..
thanks
15 REPLIES 15
I tried using before update br but as I mentioned it gave me the issue where when State was changed to Resolved and then after reloading it was moved back to In Progress on problem
Hi @tushar_ghadage ,
Please check if any script causing this issue with lower order on problem table. Try to deactivate your script and run still facing this same issue
Please mark my answer correct and helpful if this works for you
Thanks and Regards,
Sarthak
HarshitaN
Hello @tushar_ghadage
onSubmit() Client script won't work in this case. You have to use "before update BR".
    if (current.state == "106") {
        gr.addEncodedQuery('problem=' + current.sys_id + '^active=true');
        if (gr.hasNext()) {
            gs.addErrorMessage('There are active problem task.');
            current.setAbortAction(true);
})(current, previous);
Additionally, change the order of BR, so that your BR executes first.
Thanks and regards,
HN
I tried that
as shown in your screen shot state will move to resolve and then after reloading the state will move back to fix in progress that's what I don't want . ( similar is happening with me also )
Ankur Bawiskar
@tushar_ghadage
why not hide that Resolve button if any active problem task is there?
