OOTB flow for Catalog Items
AmirMohamed01
Is there an out-of-the-box (OOTB) workflow for ServiceNow catalog items — even a basic one — that I can use as a starting point to customize?
I’m looking for something that covers the following flow:
  • A request is submitted
  • A Requested Item (RITM) is automatically created
  • An approval process kicks in: first by the requester's line manager, followed by a specific approval group
  • Once approved, a catalog task is generated for fulfilment and automatically assigned to a designated support group.
BrianProvencher
Yes, it's called Step based request fulfillment. It's a flow in Flow Designer.
BrianProvencher
@AmirMohamed01 it's worth noting that you can't directly edit the OOB flows. You need to make a clone/copy and then you can edit the copy.
