other Category option are not visible based on script
Manohararuna
Hi Everyone,
I have used to below script to display Task categories(12 Category option) based  Three Assignment group(Workforce Management - APAC,/EU/US) ,But other Task categories(20) are  also not display to other Assignment groups
var allowedGroups = [
'Workforce Management - EU',
'Workforce Management - APAC',
'Workforce Management - US'
var grpDisplay = g_form.getDisplayBox('assignment_group').value;
g_form.removeOption('u_task_category');
if (allowedGroups.indexOf(grpDisplay) > -1) {
g_form.addOption('u_task_category', 'Configuration', 'Configuration');
g_form.addOption('u_task_category', 'Login', 'Login');
g_form.addOption('u_task_category', 'NSO', 'NSO');
g_form.addOption('u_task_category', 'SFTP - Global scape', 'SFTP - Global scape');
g_form.addOption('u_task_category', 'Access update', 'Access update');
g_form.addOption('u_task_category', 'Query', 'Query');
g_form.addOption('u_task_category', 'Terminate', 'Terminate');
g_form.addOption('u_task_category', 'Interface', 'Interface');
g_form.addOption('u_task_category', 'Timeclock', 'Timeclock');
g_form.addOption('u_task_category', 'Store close', 'Store close');
g_form.addOption('u_task_category', 'schedule upload', 'schedule upload');
g_form.addOption('u_task_category', 'Holiday', 'Holiday');
g_form.addOption('u_task_category', 'Reports -WFC', 'Reports -WFC');
g_form.addOption('u_task_category', 'Reports -WFAN', 'Reports -WFAN');
g_form.addOption('u_task_category', 'Automate', 'Automate');
g_form.addOption('u_task_category', 'Auto Scheduling', 'Auto Scheduling');
g_form.addOption('u_task_category', 'Forecasting', 'Forecasting');
g_form.addOption('u_task_category', 'Batch Jobs', 'Batch Jobs');
g_form.addOption('u_task_category', '', '');
}.Please tell the problem of this script
kaushal_snow
@Manohararuna ,
Issue likely comes from the use of g_form.removeOption('u_task_category'). This method removes all options from the field, including those that should remain visible, such as the default 'None' option....
check below updated code:
    var taskCategoryField = 'u_task_category';
    g_form.clearOptions(taskCategoryField);
    g_form.addOption(taskCategoryField, '', '-- None --');
        if (grpDisplay === 'Workforce Management - APAC') {
            g_form.addOption(taskCategoryField, 'Configuration', 'Configuration');
            g_form.addOption(taskCategoryField, 'Login', 'Login');
            g_form.addOption(taskCategoryField, 'NSO', 'NSO');
            g_form.addOption(taskCategoryField, 'SFTP - Global scape', 'SFTP - Global scape');
            g_form.addOption(taskCategoryField, 'Access update', 'Access update');
            g_form.addOption(taskCategoryField, 'Query', 'Query');
            g_form.addOption(taskCategoryField, 'Terminate', 'Terminate');
            g_form.addOption(taskCategoryField, 'Interface', 'Interface');
            g_form.addOption(taskCategoryField, 'Timeclock', 'Timeclock');
            g_form.addOption(taskCategoryField, 'Store close', 'Store close');
            g_form.addOption(taskCategoryField, 'Schedule upload', 'Schedule upload');
            g_form.addOption(taskCategoryField, 'Holiday', 'Holiday');
            g_form.addOption(taskCategoryField, 'Reports - WFC', 'Reports - WFC');
            g_form.addOption(taskCategoryField, 'Reports - WFAN', 'Reports - WFAN');
            g_form.addOption(taskCategoryField, 'Automate', 'Automate');
            g_form.addOption(taskCategoryField, 'Auto Scheduling', 'Auto Scheduling');
            g_form.addOption(taskCategoryField, 'Forecasting', 'Forecasting');
            g_form.addOption(taskCategoryField, 'Batch Jobs', 'Batch Jobs');
        } else if (grpDisplay === 'Workforce Management - EU') {
        } else if (grpDisplay === 'Workforce Management - US') {
        g_form.setDisplay(taskCategoryField, false);
    g_form.setDisplay(taskCategoryField, true);
In this script, g_form.clearOptions('u_task_category') is used to remove all options from the Task Category field, and then the default 'None' option is added. Subsequently, based on the selected Assignment Group, specific options are added to the Task Category field.
If you found my response helpful, please mark it as ‘Accept as Solution’ and ‘Helpful’. This helps other community members find the right answer more easily and supports the community.
