Parsing error : unexpected token
sarabjeet
Giga Expert
i am not sure why this error in coming and how can we remove it. is there any other way to call if condition please let me what have i done wrong. PFB  screenshot for reference.
try adding logs
if (gr.next()) {
            var obj = {};
            obj["Number"] = gr.number + '';
            obj["State"] = gr.state.getDisplayValue();
gs.info('state'+gr.state.getDisplayValue());
            if (gr.state.getDisplayValue() == 'In progress') {
                obj["Sub state"] = gr.hold_reason.getDisplayValue();
            inc.push(obj);
9 REPLIES 9
try adding logs
if (gr.next()) {
            var obj = {};
            inc.push(obj);
@sarabjeet
Any update on this?
Apologizes for the delay Ankur and thanks a lot for the help it worked.
You are welcome
Rachel Gomez
Giga Expert
Tips to Fix Formula Parse Errors
Check your formula inputs and make sure they're correct.
Use the IFERROR function and display a different result if an error occurs.
Check your spelling and make sure all the parentheses are in the right places.
Make sure you're using the correct operators.
Rachel Gomez
