Plan for instance setup
Options
01-29-2025 12:33 AM
Does any one have a sample documentation plan to setup an instance from scratch with catalog items, scripts, flows, and other modules that require for an instance to function.
Thank you,
Sharley
Options
01-29-2025 01:37 AM
Hello @Angel raj
Maybe you are looking for this:
Personal Developer Instances (PDIs) - ServiceNow Developer Guide
Hope this helps!
"If you found my answer helpful, please like and mark it as an "accepted solution". It helps future readers to locate the solution easily and supports the community!"
Thank You
Juhi Poddar
Thank You!
Juhi Poddar
Juhi Poddar
