Plugin - Configuration Management For Scoped Apps
Rick54
We have a requirement to activate 'Configuration Management For Scoped Apps ' plugin in sake of ScienceLogic integration. I read through the documentation but it doesn't gives me much information. I would like to understand how this plugin helpful to the existing system with an example and is there any cross impacts on existing CMDB? Thanks for your response.
Barbara L - Gli
This plugin is related to cmdb identification and reconciliation. There are APIs used to keep the cmdb clean when importing data via script, prevent duplicate records, etc.
All the plugin would do is allow you to use the identification and reconciliation APIs within your scoped app, you'd just have to use the prefix sn_cmdb.IdentificationEngine.<method>.
You can see what the APIs are designed for here along with some examples of them in use if you click in to each individual API.
Hope this helps!
Barbara L - Gli
Not a problem!
If that's what you needed if you wouldn't mind closing the thread so future people can find this if they have the same question. Just mark whichever message answered it as the correct answer.
Glad to have helped, thanks!
