Populate Catalog task description based on Variable choices
Cat
I'm hoping someone can help me with this.
I have a requirement to be able to populate the description of the request item/catalog task based on what was chosen in a variable.
For example, I have a variable called Team which has 10 different options. If Team 1 is selected, I need the description to say something like "Please assign the following roles: Role1, Role2, Role3". If Team 2 is selected, I need the description to say "Please assign the following roles: Role3, Role4, Role5" and so on.
What would be the best way for me to do this?
Thanks in advance!
Ankur Bawiskar
@Cat
you can use Advanced Script in Catalog Task Activity of workflow and set the Description of SC Task
var val = current.variables.variableName; // give variable name here
// use the correct choice values to compare
if (val == 'Team1')
    task.description = 'Please assign the following roles: Role1, Role2, Role3';
else if (val == 'Team2')
    task.description = 'Please assign the following roles: Role3, Role4, Role5';
	// and so on
Thank you - this worked best for my purposes
Sarthak Kashyap
Hi @Cat ,
Please check below script maybe it will help you
(function execute(current, previous) {
    var team = current.variables.team;  // Replace 'team' with your variable name
    if (!team) {
    if (team == 'team1') {
        current.description = "Please assign the following roles: Role1, Role2, Role3";
        current.update();
    else if (team == 'team2') {
        current.description = "Please assign the following roles: Role3, Role4, Role5";
        current.update();
    else {
        current.description = "Team selection captured. Please review assignment needs.";
        current.update();
})(current, previous);
Please mark my answer correct and helpful if this works for you
Thanks and Regards,
Sarthak
Thank you - Where would I apply this script? Is it in the workflow? Before or after the task is created?
