Populate Record producer variables with current user values
vaishali mahal1
Hello team,
i have record producer and i am able retrieve only userID.like this.
I have User[sys_user] table having details regarding this logged in user but i am not sure to retrieve that values and populate in record producer.
User[sys_user] will like this,
Mark Roethof
Hi there,
This might help:
https://www.servicenowguru.com/scripting/user-object-cheat-sheet/
For example, if it is for onLoad, you could use Default Values like:
javascript:gs.getUserID();
javascript:gs.getUser().getDepartmentID();
javascript:gs.getUser().getLocation();
etc.
Kind regards,
Mark
LinkedIn
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
Hello Mark,
THis is what happ
Vaishali
msm4
Mega Guru
Hello VAishali,
You can actually write OnChange Client script to populate the values
for example :
g_form.setValue('department', g_user.getDepartmentID());
Surendra Poosa1
Kilo Expert
You can create a catalog client script on OnChange condition to update the user information based on the login name...somewhat similar to the following code.
if (newValue == '') {
var caller = g_form.getReference('caller', popCallerInfo);
function popCallerInfo(caller){
g_form.setValue('contact_number', caller.phone);
g_form.setValue('location', caller.location);
g_form.setValue('requested_for_manager', caller.manager);
The SN Nerd
A few tips and tricks from my experience:
  • Do not use OnLoad Client Script for this - it is slow, poor UX, requires more code & completely unnecessary.
    Using an onLoad Client Script, you will notice that the values start off empty, then populate after a second or so. The more you do this, the slower your forms will be.
  • Use Default Values to populate variables for "On Load" as others have said.
    Default values = instant field population, better UX.
  • Use the official GlideUser API documentation to help populate Default Fields. It is available here. Example usage (don't forget the 'javascript:' prefix):
    javascript:gs.getUser().getMobileNumber(); //Get Mobile Number​
  • If you need to get fields that are not in the documented API, use the following code
    javascript:(function getUserField(fieldName) {
    var currentUser = gs.getUser();
      var userGR = currentUser.getRecord();
      return userGR.getValue(fieldName);
    })('email'); //Change this to the field name required​
  • If there is a use case where a user is filling out this form for someone else, write OnChange scripts to handle field changes, make sure one of your variables is a Reference field of type sys_user so it is easier to retrieve user details in your on Change Client Script. Only then can you leverage the g_form.getReference API.
        g_form.getReference('caller_id', callback);
    function callback(caller) { // reference is passed into callback as first arguments
       g_form.setValue('full_name',caller.name);
ServiceNow Nerd
ServiceNow Developer MVP 2020-2022
ServiceNow Community MVP 2019-2022
