Popup for cancel confirmation not working
Roshini
I am trying to create a UI Action with name 'Cancel RITM', which will be asking for reason for cancellation, and cancel /Ok button. Once Ok is clicked, it will verify if there is some value or not, if no value it will give an info message and won't allow to proceed further, If value is there it will allow to make the RITM closed incomplete( value =4) and update the work notes with "Cancelled: " + cancel comments.
Below is the UI action and Ui page am trying, but it is not working as expected, am not getting any error.
Just the OK button is not validating anything and updating anything. It is redirecting to "ui_page_process" page with UI action sys id.
Ui action
function cancelRITM()
    var dialog = new GlideDialogWindow ('cancel_reason_dialog');
    dialog.setTitle('Cancellation Reason');
    dialog.setSize(750, 300);
    dialog.setPreference('sys_id', g_form.getUniqueValue()); // Pass current record ID
    dialog.render();
Ui page
HTML
    <g:ui_form>
        <!-- Capture current record ID passed from UI Action -->
        <input type="hidden" name="sys_id" value="${RP.getWindowProperties().get('sys_id')}" />
        <table width="100%">
            <tr>
                <td>
                <p>Please provide a reason for cancellation:</p>
                    <textarea id="cancel_comments" name="cancel_comments" rows="4" style="width:100%"></textarea>
                </td>
            </tr>
            <tr id="dialog_buttons">
                <td align="right">
                    <!-- UI Macro for standard OK/Cancel buttons -->
 <g:dialog_buttons_ok_cancel ok="validateReason()" ok_type="submit"
                                            cancel="cancelDialog()" cancel_type="button"/>
                </td>
            </tr>
        </table>
    </g:ui_form>
</j:jelly>
Client script
function validateReason() {
    var reason = gel('cancel_comments').value.trim();
    if (reason == "") {
        alert("Cancellation reason is mandatory.");
        return false; // Blocks submission
    return true; // ALLOWS submission to Processing Script
function cancelDialog() {
    GlideDialogWindow.get().destroy();
    return false;
Processing script
    var gr = new GlideRecord('sc_req_item'); // Or your target table
    if (gr.get(sys_id)) {
        gs.info("@ro inside 1")
        gr.state = 4; // 'Cancelled' state
       // gr.close_notes = "Cancelled: " + cancel_comments;
        gr.update();
        // Redirect back to the form or list
        response.sendRedirect("sc_req_item.do?sys_id=" + sys_id);
Naveen20
The journal field assignment method and potentially the textarea value not posting cleanly. Here's what to fix:
1. Processing Script — use setValue() for journal fields:
Journal fields like work_notes don't reliably accept direct assignment in all contexts. Replace the direct assignment:
var sysId = RP.getParameterValue('sys_id');
var cancelComments = RP.getParameterValue('cancel_comments');
// Debug: check what's actually coming through
gs.info("Cancel RITM - sys_id: " + sysId);
gs.info("Cancel RITM - comments: " + cancelComments);
if (gr.get(sysId)) {
    gr.setValue('state', 4);
    gr.setValue('work_notes', 'Cancelled: ' + cancelComments);
    gr.update();
response.sendRedirect("sc_req_item.do?sys_id=" + sysId);
2. Client Script — copy the textarea into a hidden input before submitting:
Textarea values can sometimes get lost during form POST in UI Pages. The safest approach is to relay the value through a hidden input:
Update the HTML to add a hidden field:
<input type="hidden" id="hidden_comments" name="cancel_comments" value="" />
Then remove the name attribute from the textarea so only the hidden field posts:
<textarea id="cancel_comments" rows="4" style="width:100%"></textarea>
And update the client script to copy the value before submitting:
function validateAndSubmit() {
    if (reason === "") {
        return false;
    // Copy textarea value into the hidden input before submit
    gel('hidden_comments').value = reason;
    document.forms[0].submit();
    return false;
The gs.info lines in the processing script will log to the system log, so you can check System Logs > System Log > All to confirm whether the values are actually arriving. If cancel_comments shows as null or empty there, it confirms the textarea POST issue. The hidden input relay approach is the standard workaround for this in ServiceNow UI Pages.
pr8172510
Hi Roshini,
I tried your approach and was able to fix the OK button issue  (it was due to missing return in the dialog button / submission handling).
However, I’m still facing an issue with the record update part:
 Current Behavior
  • Popup opens correctly
  • Validation works (empty reason is blocked)
  • On clicking OK → dialog closes
 But:
State → NOT changing
Stage → NOT updating
Work notes → NOT getting updated
 What I Observed
Even though the processing script runs, the RITM remains:
State = Open
Stage = Waiting for Approval
Looks like something is overriding or blocking the update.
function cancelRITM() {
    var dialog = new GlideDialogWindow('cancel_reason_dialog');
    dialog.setSize(600, 300);
    dialog.render();
<j:jelly trim="false" xmlns:j="jelly:core" xmlns:g="glide">
<g:ui_form method="post" action="cancel_reason_dialog.do">
    <input type="hidden" name="sysparm_name" value="cancel_ritm" />
        <tr>
            <td>
            </td>
        </tr>
        <tr>
            <td align="right">
                <button type="button" onclick="submitForm()">OK</button>
                <button type="button" onclick="cancelDialog()">Cancel</button>
            </td>
        </tr>
    </table>
</g:ui_form>
</j:jelly>
function submitForm() {
    var reason = gel('cancel_comments').value;
    if (!reason || reason.trim() == "") {
        return false;
    return false;
if (request.getParameter('sysparm_name') == 'cancel_ritm') {
    var sys_id = request.getParameter('sys_id');
    var cancel_comments = request.getParameter('cancel_comments');
        if (!cancel_comments || cancel_comments.trim() == "") {
            gs.addErrorMessage("Cancellation reason is mandatory.");
            response.sendRedirect("cancel_reason_dialog.do?sys_id=" + sys_id);
            gr.state = 4; // Closed Incomplete
            gr.work_notes = "Cancelled: " + cancel_comments;
            gr.update();
            gs.addInfoMessage("RITM cancelled successfully");
am not seeing the processing script running, am not getting any logs
Ankur Bawiskar
@Roshini
why not use javascript prompt box where user can enter the reason?
Grab it and update the record
no need of UI page
Can you please help me the code
I thought of below
UI action script
function promptForReason() {
var reason = prompt("Please enter the reason for this update:");
if (reason) {
var ga = new GlideAjax('RecordUpdateHandler');
ga.addParam('sysparm_name', 'updateReason');
ga.addParam('sysparm_id', g_form.getUniqueValue());
ga.addParam('sysparm_reason', reason);
ga.getXMLAnswer(function(response) {
if (response === 'success') {
g_form.addInfoMessage('Updated successfully.');
g_form.refresh();
Script include
var RecordUpdateHandler = Class.create();
RecordUpdateHandler.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    updateReason: function() {
        if (gr.get(this.getParameter('sysparm_id'))) {
            gr.work_notes = "Reason: " + this.getParameter('sysparm_reason');
            gr.update();
            return 'success';
        return 'error';
But am not able to save the Ui action script.
