Post button not available on journal_input field.
07-19-2018 10:09 AM
We have two journal_input fields comments, work notes on the catalog task form. The post button is available only for work notes and not comments. How do I get it even for the other field too?
RK
If my response is helpful, please select Helpful. If my response answers your question, please select Accept as Solution.
Request Management
07-19-2018 11:07 AM
Can you try looking at the form layout and make sure that work notes is right below additional comments. There appears to be something in between them. Looking at it in form designer may be easier.
07-19-2018 12:10 PM
I looked at the form layout and it has RITM Comments & Work Notes too. But I could find these on form or list view too.
When I try to record something on addl. comments, they're not recorded on the activity filter like you see in below image. I modified the description, work notes and they are recorded in the activity filter.
RK
07-19-2018 12:17 PM
I would remove the requested item.comments. It looks like you have the requested item comment and the task comments on the same form. It may be displaying the wrong one so it will not show properly in the comments and the post will not work as the post is for the task fields.
07-19-2018 10:25 AM
07-19-2018 11:03 AM
I tried the same and added the Additional Comments to Activity filter. But it did not help and I should still save the addl. comments using the 'Update' button or saving the form.
RK
