11-29-2020 09:08 AM
We are thinking of using Power BI as a reporting tool from Service Now. What I would like to know is:
1. What is the best way to form the connection between the 2 systems. Does a connector exist?
2. Anyone aware of any licencing restrictions?
3. Can this impact performance on Service Now?
Riaz
11-29-2020 09:29 AM
Please find points below:
- If you are planning to allow Power BI to fetch ServiceNow data then you can either use OOB table API or Scripted REST API - no license issue here
- If you are planning to consume Power BI API and push data from ServiceNow by consuming REST or SOAP message then also there won't be any license issue.
Impact in performance - If Power BI is consuming ServiceNow endpoint like once in every 5mins or less to pull the table data it would lead to impact to the instance. I would suggest to do this in off-business hours.
Refer below links for help
How to explore serviceNow Data with Power BI
Show reports in power bi for problem list
Connecting to RestAPI from Excel or PowerBI and getting all fields in security incident to display
05-20-2022 09:42 AM
11-04-2022 05:31 AM
Hi!
You can consider Power BI Connector as a means to integrate both platforms and pull ServiceNow data into Power BI for further use.
Cheers,
Khrystyna
