Preventing Duplicate CIs
eddiemorales
We have users that are constantly adding New CIs/Phone Numbers and having an issue with duplicate phone #s being added because those are simply not being checked consistenly to see if it already exists. What is the best way to prevent this creation of duplicate phone#s? Business rule, etc? We are looking more in the lines of having a flag or something where once the # is saved, it prompts that "this # already exists" and denies the creation of the new #.
Thanks!
Hi Eddie,
Sorry, it is supposed to be gs.addErrorMessage() and not current.addErrorMessage().
Here is the complete script:
  var gr = new GlideRecord('u_phone_numbers');
  gr.addQuery('name',current.name);
  gr.addQuery('u_switch',current.u_switch);
  if(gr.next()) {
      gs.addErrorMessage("The phone number on the selected switch is already in use");
      current.setAbortAction(true);
})(current, previous);
I hope this gets you what you need.
/Lasse
16 REPLIES 16
Hi Eddie,
  if(gr.next()) {
/Lasse
Good Morning Lasse,
It looks like this is going to work!
Thank you so much…your help is much appreciated!
Eddie
Hi Eddie,
You are welcome. Please remember to mark the correct answer as "Correct". This way others can easily find the correct answer and does not have to scroll through our conversation.
Also it gives me points 🙂
Kind regards
Lasse
Will do…! I do have another question though lol! Would it be a difficult to have a "If" query to where unless it is a 3 digit phone # (could span across multiple switches), everything else regardless of the switch or not does not allow dupes. In other words, when a 3 digit phone # is entered, the current code looks at switch and #. Moreover, anything above 3 digits entered just looks at the phone# regardless of switch and flags duplicates.
Thanks!
Eddie
Hi Eddie,
Yes, sure. You can always add an if statement and only include the switch in case the number is longer than 3 characters.
I added this twice in below example so that you can also have different errors depending on if the error is with the phone and switch or just the phone:
  if(current.name.toString().length > 3)
  if(gr.next()) {
      else
          gs.addErrorMessage("The phone number is already in use");
Have a nice day!
/Lasse
