Preview is not available for a custom reference field.
abhisek
I have created a custom reference field xyz and have written a on change client script to populate the xyz field value as per the existing reference field caller on the incident form.
Value of xyz field is getting populated properly as per caller field but preview is not available for the xyz field.
Can anyone please help me out.
Ankur Bawiskar
@abhisek
you just want to set value of caller into another field then why to use getReference
directly set it like this
g_form.setValue('u_affected_user', g_form.getValue('caller_id'));
Ankur Bawiskar
@abhisek
Hi Ankur,
It is working now. Thanks a lot for your help ðŸ˜Š
Abhisek
PavanK960672992
Mega Patron
Hi @abhisek  ,
If you are trying to set same value on different field then why you need 2 different fields?
If it helps please click Accept as Solution/hit the Thumb Icon.
ServiceNow Community MVP 2024.
Pavankumar
