Problem Management roles responsibilities
11-09-2022 08:07 PM
Does anyone explain the roles and responsibilities for the below given problem roles
1.problem_admin
2.problem_manager
3.sn_problem_read
4.sn_problem_write
11-09-2022 09:26 PM
Hi @Yasin Shaik11 ,
1. Problem_Admin :Responsible for the overall problem management process as well as delete problems and problem tasks.
2. Problem_Manager :Responsible for the overall problem management process and can configure problem management settings as well as act as a problem coordinator.
3. sn_problem_read :Read access to the Problem Management application and related records.
4.sn_problem_write:Write access to the Problem Management application and related records.
11-09-2022 09:36 PM
Hi Gunjan,
Thanks for your reply
I can see this explanation in the roles table. but my client is asking in depth explanation about each role.
Like for example problem_coordinator role : can do
periodically perform analysis to see if new problems need to be registered.
Register problems.
Assign work to Problem Analysts and coordinate root cause analysis.
Register known errors.
Inform Problem Manager.
Assign known error to Problem Analyst.
Validate proposed solutions to known errors.
Validate outcome of closed changes and close known error.
Validate that a problem is solved
11-09-2022 09:38 PM
Hi @Yasin Shaik11 ,
For that I will suggest to take help from someone who is having hands on in depth experience in problem management.
11-09-2023 06:27 AM
You will find a really useful and practical guide in this document:
https://its.yale.edu/sites/default/files/ServiceNow_Problem_Process_Training_Draft_r3.pdf
if Helpful, please mark as Correct/Helpful.
