Problem Management error in ATF
Sriram Pusuluri
Hi Team,
I am running ATF for Problem management, I am receiving below error
If I open the screenshot of the error, Assess button is showing
Assigned to is having Problem_manager, itil roles.
How to resolve this error
Dr Atul - LNG
We ran ATF for prb last week n has no issue. Please repair the ATF plugin once.
I have repaired the Plugin and ran again, still same issue.
Below are my steps:
@Dr Atul - LNG  Any suggestions?
Hi @Sriram Pusuluri
It should work, as this is standard OOTB functionality and does not require any manual intervention. I would recommend logging a now support case with the team to investigate, as this is expected behaviour out of the box.
