‎02-11-2026 12:22 PM
I noticed that the Priority matrix is not updating in a problem ticket. I can change both options to High, but te Priority will remain in Planning. It works in an incident ticket. What could be the disconnect?
‎02-11-2026 02:50 PM
Wired, might be cache issue then. Try cache.do , if still not work log a case to now support.
‎02-11-2026 02:57 PM
The cache.do did not resolve the issue. I will open a support ticket.
Thanks!
‎02-11-2026 12:50 PM
Check here is all active or not:
‎02-11-2026 12:54 PM
‎02-11-2026 02:40 PM
Hi @Menalik
Is it working for other combinations as shown in the screenshot, or is nothing working at all? Did you check the matcher table?
Also, please verify whether the data lookup is functioning correctly.
‎02-11-2026 02:49 PM
