Project baseline - is there a way to schedule a baseline?
skendy
I have been asked if there is a way to schedule (or an automatic procedure) a baseline in the project related lists?
I was thinking a kind of any specified date or time to have a 'snapshot' of the project tasks state and actual dates and progress.
I suggested scheduling reports, but it is not the same thing...
Thank you for any help,
Skender
Change this line as per your requirement
projects.addEncodedQuery("active=true^state=1");
Baselines parent table is 'planned_task_baseline'. The script is for creation of baselines . You may run a scheduled report to automatically retrieve the data
21 REPLIES 21
Anurag Tripathi
Giga Patron
Hi Skender,
There is already and OOB related list on projects called "Baseline" , you can use it to efficiently create and use project baselines.
Read this for more info
Updating a Project in Progress - ServiceNow Wiki
Hi Anurag,
Yes, I have already added it,
but I was thinking of an automatic baseline (like the scheduled reports).
Anyway, is a P3 priority for the client.
Thank you,
Skender
You may open this UI page 'create_baseline' and check its processing script .. Make use of the same in a scheduled job to automate the process of baseline creation
Hi Kalai,
Yes I understand and I appreciate your suggestion
but I am no expert in scripting and I do not want to make any damage now...
Do you have any example of such script?
The only requisite is to schedule the baseline every Friday night (for example)...
Skender
