‎01-04-2022 02:03 AM
Hi Experts,
There is one requirement that i have,
I have have given the itil role to the "Show Flow" UI action and after click on that flow is not visible. Just because of limited access on the flow designer.
On which table I need to create the read ACL so that I can provide the read access of the flow designer to the ITIL user.
Change Management
‎01-04-2022 05:18 AM
try to add flow_operator role as contained role under itil and then check
I added flow_operator under itil and it showed me the flow context
‎05-05-2023 06:02 AM
On the UI action itself you need to then add the ITIL role to the requires role related list.
‎05-05-2023 06:34 AM
Thanks Dan! Unfortunately, that doesn't seem to be quite it... When I check Requires role under the Show Flow UI Action, flow_operator and itil roles are there, already
‎08-29-2025 12:57 PM
was this ever resolved? i have the same ask
