Query Business rule based on assignment group
pooja53
Kilo Explorer
Hi Team,
I am writing the query Business rule. Where if Logged in user is member of that group, then only incidents belongs to that assignment group should be visible.
Before query business rule on Incident.
it works when I send Sys_id of that group example:
if(gs.getUser().isMemberOf('f795ab34db230010bdfd0181ca96196b'))
current.addQuery('assignment_group','f795ab34db230010bdfd0181ca96196b');
Its Not working below one.
if(gs.getUser().isMemberOf(current.assignment_group))
current.addQuery('assignment_group',current.assignment_group);
Adrian Script will work after making one modification:
if (gs.getUser().isMemberOf(gs.getProperty('property_name'))) {
current.addQuery('assignment_group', gs.getProperty('property_name'));
If it was helpful, Please mark it helpful.
Harshal Aditya
Hi Pooja,
You have to pass Sys_ID if you are using before query BR. As it runs when any user queries any table. So cunnent.assignment group will not work.
Harshal
sayed3
Before Query business rule:
    var userGroupsRaw = gs.getUser().getMyGroups();
    var userGroups = Array.isArray(userGroupsRaw) ? userGroupsRaw : Array.from(userGroupsRaw || []);
    gs.info("User Groups: " + JSON.stringify(userGroups));
    if (userGroups.length > 0) {
        var groupFilter = userGroups.map(function(groupId) {
            return "assignment_group=" + groupId;
        }).join("^OR");
        gs.info("Constructed group filter: " + groupFilter);
        var query = "active=true^" + groupFilter;
        gs.info("Final encoded query: " + query);
        current.addEncodedQuery(query);
        gs.info("User has no groups; applying ISEMPTY filter");
        current.addEncodedQuery("active=true^assignment_groupISEMPTY");
})(current, previous);
