Question Regular Expression Currency
Krishna101
Hi Community,
I have cretaed variable name is Amount and type as single line text. I have created Question Regular Expression for this variable to all format of $12.00.
Question Regular Expression :  ^\$[0-9]+\[,]+\.?[0-9]*$
but user want to this format only to allow $4,000,000.00
How can create Question Regular Expression to allow above format. Could you please help into this.
Thanks in Advance
Krishna
Hi @Krishna101
Instead of creating and using a validation regex pattern, could you please try creating an onChange client script like the one below?
Type: onChange
Variable Name: currency (your_variable_name)
script:
   // Regular expression to match the format $4,000,000.00
    var regex = /^\$[1-9]{1}(?:\d{0,2}(?:,\d{3})*)?\.\d{2}$/;
    // Get the value of the Amount field
    var currencyValue = g_form.getValue('currency');
    // Check if the Amount field value matches the regex pattern
    if (!regex.test(currencyValue)) {
        // If not matched, display an error message
        g_form.showFieldMsg('currency', 'Please enter the amount in the format $4,000,000.00', 'error');
        // Clear the field message if the value matches the pattern
        g_form.clearMessages();
Here are some outputs:
If this also doesn't work, try replacing the regex pattern in the script as provided in this thread.
Let me know if it works for you!
Please mark this as "correct" and "helpful" if you feel this answer helped you in anyway.
Thanks and Regards,
Ashish
13 REPLIES 13
Its not allowing the format
AniketC85155510
Hello @Krishna101 ,
Please give a try to the Regular Expression below and see how it works for you.
^\$[1-9]\d{0,2}(?:,\d{3})*(?:\.\d{2})?$
Let me know if you still face any issues with this.
Please Mark ✅Correct if this solves your query and also mark 👍Helpful if you find my response worthy based on the impact.
Aniket
Hi Chavan,
Thanks for your help, but no luck its not working
Thnaks
Krishna
@Krishna101  - Oh, okay! Please try this updated version. I’ve made a few slight adjustments:
^\$[1-9]\d{0,2}(,\d{3})+\.\d{2}$
This should match formats like $4,000,000.00 with commas and exactly two decimal places. Let me know if it works for you!
Hi Chavan,
Please find the error
Please find my configuration
