"Username and Password" in system properties
Vinay nalla
how can we set the 'username and password' in system properties..
@Vinay nalla
Hope you are doing good.
Would you mind marking the best matching answer as correct and helpful, to close this thread?
Thanks!
15 REPLIES 15
Ankur Bawiskar
@Vinay nalla
I would encourage to use password type of property for password & string for username as suggested by Ashutosh.
But still if you want to set single property then you would require to use json string as value; for better maintenance
something like this
Name - authenticataion_details
Value - {"user_name":"abel.tuter","password":"abel123"}
Then you will have to parse it where you want to retrieve it
something like this
var val = gs.getProperty('authenticataion_details');
var parser = JSON.parse(val);
var userName = parser.user_name;
var password = parser.password;
@Vinay nalla
Let me know if I have answered your question.
If so, please mark appropriate response as correct & helpful so that this thread can be closed and others can be benefited by this.
@Vinay nalla
@Vinay nalla
Let me know if I have answered your question..
@Vinay nalla
