Read only field is not greyed out on portal.
PK16
Hello
I have one field on catalog item and I make it read-only but it is not greyed out. I don't know why.
That field is not editable.
Guys, please suggest something.
Field : Job title.
Gunjan Kiratkar
Hi ,
Did you get the resolution on this ? I also face the same issue ,better to create the HI ticket for this. In my case even if I create new variable with single line text and make it read only from dictionary level or using UI policy then it makes that field read only but not greyed out. But if I change the field type to reference then it was working fine. May be it is instance issue because of upgrade.
Gunjan Kiratkar
17 REPLIES 17
HI Gunjan,
Did you get any resolution for this? Apparently, sp-variable-editor renders the reference/choice fields greyed out as default. Instead of a widget clone and making custom changes, what other approach can be taken here?
Sagar Pagar
Check the other Catalog UI policies working on same field, with reverse of false make it as non-read only/ editable.
Sagar Pagar
tim2222
Giga Guru
For anyone else finding this post in future I raised this with support and they stated this is "working as expected". The confusion arises that in Service Portal inputs are consistently greyed out, whereas in employee center (EC Pro / EC Theme) text and textarea are not greyed out.
To make EC Theme behave the same as Service Portal add a CSS Include.
  1. Switch to Employee Center application.
  2. Navigate to sp_css.do
  3. Create a new CSS include with:
    input:read-only, textarea:read-only { color: #000 !important; background-color: #e6e8ea !important; }
  4. Navigate to Service Portal > Themes.
  5. Open EC Theme.
  6. In CSS Includes related list add the CSS include you just created.
