Record producer fields mapping
DSV22
Hi team,
I have 3 fields in record producer to map with the 3 fields with incident form which I have done.using the script
current.business_service = producer.field_name;
current.category= producer.field_name;
Category field is taking the backend choice value and the Business services field is not taking any value since it is a reference field in the incident form
Can anyone please suggest how to achieve this task to populate the exact values which is selected while submitting the form.
11 REPLIES 11
Hi @DSV22 ,
Apologies my bad, u need to use only 1 = sign in this line
current.business_service == gr.sys_id;
Can u try by removing the extra equals to line & check if it works
Danish
HI @Danish Bhairag2
Still the same service field is not reflecting
Hi @DSV22 ,
Could u pls log producer.application_affected for me plz & let me know what is coming
Use this
gs.info("Business Service1"+producer.application_affected);
gs.info("Business Service2"+producer.application_affected.getDisplayValue());
Do this logs at the very 1st line before the actual code. Once executed can u then check logs & let me know what is the value coming for both
Danish
Hi @Danish Bhairag2
Please check the logs
Hi @DSV22 ,
Assuming in ur service table u already have the application. Plz try below updated code:
var gr = new GlideRecord('cmdb_ci_service');
gr.addQuery('name',producer.application_affected.getDisplayValue());
if(gr.next()){
current.business_service = gr.sys_id;
Danish
