Reference Field List Layouts -- Not functioning correctly after deploying update set
12-11-2014 12:02 PM
I modified the List Layout for a reference field variable pop up in a catalog item (the pop up that appears after clicking the little magnifying glass). This modification was successfully captured in my update set, which I deployed to another instance for testing. In the target instance, however, the list layout for the catalog item I created does not match the way I defined it in the original instance. I captured the update to the List Layout again in another update set and deployed it, but that didn't resolve the issue.
Here's what it looks like in my update set:
| 2014-11-20 12:03:45 | List Layout | sys_ref_list | Server | sys_ui_list_cmdb_ci_server_sys_ref_list |
Any ideas on how to resolve this issue? I found a few posts on the Community regarding the layout, but not about transferring it across instances in an update set.
Thank you!
Service Catalog
12-11-2014 01:06 PM
No worries . . . both fields have the same sys_id?
