Reference qualifier not working as expected
Yasin Shaik11
Need help for the below.
In custom table we have a company and department reference fields. Here whenever user selects the company like for example user select the company of ACME Japan then I want to show Department records which are associated with the company of the ACME Japan company those departments like HR and IT and customer support. For that I have implemented a Advanced reference qualifier on Department field as follows. But this is not working as expected.  and also, whenever i save the dictionary record of Department field immediately advanced option gets removed and shows only simple qualifier and when i change it to advanced then i can be able to see the script which i have mentioned as below. is this normal behavior? Please confirm.
Use reference qualifier : Advanced.
Reference qual : Javascript:new DepartmentValues().FilterDepartment(current.company);
FilterDepartment: function(currentRecord) {
        gs.log('DEP001'+currentRecord); // name
        var company = currentRecord.name;
        var DepartmentGr = new GlideRecord('cmn_department');
        DepartmentGr.addQuery('company', company);
        DepartmentGr.query();
        var departmentLIst = [];
        while (DepartmentGr.next()) {
            departmentLIst.push(DepartmentGr.name);
        var departmentFilter = departmentLIst.join(',');
        return departmentFilter;
        gs.log('DEP002' + departmentFilter);
Hi @Yasin Shaik11
Make put this reference qualifier
javascript:'company='+current.u_administrator_company;
I have tried with but its not working and i can able to see the all the department values in department field as attched.
Vishal Birajdar
Hi @Yasin Shaik11
In Reference qualifier you can put below code
javascript:"company=" + current.getValue("company");
Ankur Bawiskar
@Yasin Shaik11
you can use advanced ref qualifier and script include is not required
something like this
javascript:'company=' + current.company;
